- Kingston SKC1000 - SSD - 960 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 960 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- M.2 2280
- Interface
- NVM Express (NVMe), Phison PS5007-E7 controller
- 22 mm x 80 mm x 3.5 mm
- 10 g
- 5-year warranty
- Capacity
- 960 GB
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
- 3.5 mm
- 10 g
Performance
- Drive Writes Per Day (DWPD)
- 0.58
- SSD Endurance
- 1 PB
- Internal Data Rate
- 2700 MBps (read) / 1600 MBps (write)
- 4KB Random Read
- 190000 IOPS
- 4KB Random Write
- 165000 IOPS
- Maximum 4KB Random Write
- 190000 IOPS
- Maximum 4KB Random Read
- 290000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 0.11 Watt (idle) , 0.99 Watt (average) , 4.95 Watt (read) , 7.4 Watt (write)
- Software Included
- Coupon code for hard drive cloning software
- OS Required
- Windows 8 / 8.1 / 10
- Included Accessories
- Low profile bracket, full height bracket, half-height half-length PCIe x4 adapter
- Limited warranty - 5 years , Technical support
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 20-1000 Hz
