Kingston 8GB HyperX Blu 1333MHz DDR3 DIMM 240-pin Non-ECC CL9
Quicklinx: 89HVWS00 Mfr#: KHX13C9B1/8
HyperX blu - DDR3 - module - 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory module
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Unbuffered
Voltage
1.5 V
Lead Plating
Gold
8 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Module Configuration
1024 x 64
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
