Product
Kingston 8GB DDR4 DIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2V Registered with Parity ECC
Quicklinx: CB4SWS00 Mfr#: KVR24R17S4L/8
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - 8 GB - DIMM 288-pin - registered with parity
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin very low profile
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
1024 X 72
Chips Organization
1024 x 4
Voltage
1.2 V
Lead Plating
Gold
RoHS
