Product
Kingston 8GB DDR4-2400MHz Reg ECC Module
Reduced Price - Whilst Stocks Last!
Quicklinx: C548WS00 Mfr#: KTL-TS424/8G
Type: DDR4 SDRAM
Capacity: 8GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
Hurry, only 3 left in stock!
£82.44 ex VAT
£98.92 inc VAT
Express delivery Order within the next 3 hours for delivery tomorrow
Kingston manufacture the most reliable memory you can buy for a Lenovo Server. Kingstons legendary reputation is built around reliable memory, that will power your Lenovo server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Lenovo compatible memory module.
Each chip that is built onto the Lenovo memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of Lenovo server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Lenovo memory upgrades for Server environments.
Kingston - DDR4 - 8 GB - DIMM 288-pin - registered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Registered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
Lenovo Flex System x240 M5 9532; Storage DX8200C 5120; System x3650 M5 8871
8 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Registered
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
Lenovo Flex System x240 M5 9532 , Lenovo Storage DX8200C 5120 , Lenovo System x3650 M5 8871
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Stock Status: Clearance
Price Range Ex VAT: 50 - 100
