Product
Kingston 8GB DDR4-2400MHz Reg ECC Module
Quicklinx: C53TWS00 Mfr#: KCS-UC424/8G
Kingston manufacture the most reliable memory you can buy for a Cisco Server. Kingstons legendary reputation is built around reliable memory, that will power your Cisco server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Cisco compatible memory module.
Each chip that is built onto the Cisco memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of Cisco server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Dell memory upgrades for Server environments.
Kingston - DDR4 - 8 GB - DIMM 288-pin - registered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Registered
Voltage
1.2 V
Lead Plating
Gold
Cisco UCS-MR-1X082RV-A
Limited lifetime warranty (Russia - 10 years)
Cisco UCS B200 M4, Smart Play 8 B200, SmartPlay B200 M4, SmartPlay Select B200 M4
8 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Registered
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
Cisco UCS SmartPlay B200 M4 Advanced 1, SmartPlay B200 M4 Advanced 2, SmartPlay B200 M4 Advanced 3, SmartPlay B200 M4 Advanced 4, SmartPlay B200 M4 Basic 1, SmartPlay B200 M4 High Core 1, SmartPlay B200 M4 High Core 2, SmartPlay B200 M4 High Frequency 1, SmartPlay B200 M4 High Frequency 2, SmartPlay B200 M4 High Frequency 2 (Not sold Standalone ), SmartPlay B200 M4 High Frequency 3, SmartPlay B200 M4 Standard 1, SmartPlay B200 M4 Standard 1 (Not sold Standalone ), SmartPlay B200 M4 Standard 2, SmartPlay Select B200 M4 Advanced 1, SmartPlay Select B200 M4 Advanced 1 (Not sold Standalone ), SmartPlay Select B200 M4 Advanced 1 (Tracer), SmartPlay Select B200 M4 Advanced 2 (Not sold Standalone ), SmartPlay Select B200 M4 Advanced 2 (Tracer), SmartPlay Select B200 M4 Advanced 3 (Not sold Standalone ), SmartPlay Select B200 M4 Advanced 3 (Tracer), SmartPlay Select B200 M4 Advanced 4, SmartPlay Select B200 M4 Advanced 4 (Not sold Standalone ), SmartPlay Select B200 M4 Advanced 5, SmartPlay Select B200 M4 Advanced 5 (Not sold Standalone ), SmartPlay Select B200 M4 Basic 1, SmartPlay Select B200 M4 Basic 1 (Not sold Standalone ), SmartPlay Select B200 M4 High Core 1, SmartPlay Select B200 M4 High Core 1 (Not sold Standalone ), SmartPlay Select B200 M4 High Core 2 (Not sold Standalone ), SmartPlay Select B200 M4 High Frequency 1 (Not sold Standalone ), SmartPlay Select B200 M4 High Frequency 1 (Tracer), SmartPlay Select B200 M4 High Frequency 2 (Not sold Standalone ), SmartPlay Select B200 M4 High Frequency 2 (Tracer), SmartPlay Select B200 M4 High Frequency 3, SmartPlay Select B200 M4 High Frequency 3 (Not sold Standalone ), SmartPlay Select B200 M4 High Frequency 3 (Tracer), SmartPlay Select B200 M4 Standard 1 (Not sold Standalone ), SmartPlay Select B200 M4 Standard 1 (Tracer), SmartPlay Select B200 M4 Standard 2, SmartPlay Select B200 M4 Standard 2 (Not sold Standalone ), SmartPlay Select B200 M4 Standard 2 (Tracer)
