Product
Kingston 8GB DDR4-2400MHz Reg ECC Module
Quicklinx: CFSLWS00 Mfr#: KCP424RS4/8
Kingston - DDR4 - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - CL17 - 1.2 V - registered - ECC
Kingston - DDR4 - 8 GB - DIMM 288-pin - registered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Single rank, registered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
