Kingston have been manufacturing high quality memory RAM components for computer upgrades for desktops, laptops, servers, motherboards and more for over 25 years with a keen emphasis on total quality. All memory chips are sent directly from the DRAM manufacturer to Kingston assembly plants to minimise handling and reduce the chance of damage and this ensures Kingston are involved in the total manufacturing process from start to finish. This Kingston KCP421SS8/4 4GB DDR4 2133MHz Non ECC Memory RAM SODIMM module has been part of that process. Kingston offers lifetime warranrty on all its memory modules to back up its assurance of quality. Kingston is involved in the DRAM process from the dicing of the wafer to encasing the integrated circuits and from assembling the module to testing the finished product meaning Kingston are involved in every part of the manufacturing process to ensure excelletn quality control.
- Kingston - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Unbuffered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- HP P1N52AA, Lenovo 4X70K09921, HP 798034-001, Lenovo 03T7467
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- Non-ECC
- Unbuffered
- Module Configuration
- 1024 x 64
- Voltage
- 1.2 V
- Lead Plating
- Gold
