Kingston 8GB DDR3L DIMM 240-pin 1600 MHz/PC3L-128 CL11 non-ECC
CLEARANCE!
Clearance
Quicklinx: C5CKWS00 Mfr#: KCP3L16ND8/8
Type: DDR3L SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
Hurry, only 3 left in stock!
£30.08 ex VAT
£36.09 inc VAT
Kingston Technology offers extremely reliable, high-performance notebook memory. Every module is customised and tested to meet the exact specification requirements of each system. Kingston memory can increase the processing power of your notebook. It’s guaranteed to be compatible and offers a great cost-performance benefit plus better multitasking, faster processing of multimedia files and smoother video streaming. For added peace of mind, Kingston memory is backed by a lifetime warranty, free technical support and legendary Kingston reliability.
Kingston - DDR3L - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - unbuffered
Memory module
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Low Voltage, unbuffered
Voltage
1.35 V
Lead Plating
Gold
HP N1M47AA
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
HP N1M47AA
DRAM memory module
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
Non-ECC
Module Configuration
1024 x 64
Voltage
1.35 V
Lead Plating
Gold
Colour Category
Green
Type: DDR3L SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3L-12800
Brand: Kingston
