Your basket is empty
Kingston 8GB DDR3 1600MHZ ECC REG MODUL
Quicklinx: BRFZWS00 Mfr#: KFJ-PM316E/8G
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: ECC
1 in stock
£61.87 ex VAT
£74.24 inc VAT
Standard delivery Delivered within 3-5 working days
Marketing description is not available.
Kingston - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
Fujitsu Celsius M720, W520
8 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Kingston 8GB DDR3 1600MHZ ECC REG MODUL Bundle deal on Kingston 8GB DDR3 1600MHZ ECC REG MODUL
£78.19
saving £8.65
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1600MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
Standard: PC3-12800
Brand: Kingston
Price Range Ex VAT: 50 - 100
