Your basket is empty
Kingston 8GB DDR3 1333MHz CL9 DIMM Memory
Quicklinx: CFTCWS00 Mfr#: KTD-XPS730B/8G
This DDR3 1333 MHz Dimm Memory module by Kingston is a product which gives high quality. With such large amount of memory you can open more applications simultaneously while providing the power needed to make them run quickly.
Additionally, this RAM module enhances the performance of your system allowing you to work faster and reap improved performance of up-to-date applications and operating systems. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
Maximize the value of your computer investment with an easy-to-install, reliable memory upgrade and you will notice that everything starts working smoothly.
Kingston - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
Dell OptiPlex 790
8 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Dell OptiPlex 790
