Your basket is empty
Kingston 8GB 2400MHz DDR4 ECC Reg CL17 DIMM 1Rx4
Quicklinx: C11NWS00 Mfr#: KVR24R17S4/8
Type: DDR4 SDRAM
Capacity: 8GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
Hurry, only 1 left in stock!
£84.64 ex VAT
£101.56 inc VAT
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
1024 X 72
Chips Organization
1024 x 4
Voltage
1.2 V
Lead Plating
Gold
Colour Category
Green
RoHS
Kingston 8GB 2400MHz DDR4 ECC Reg CL17 DIMM 1Rx4 Bundle deal on Kingston 8GB 2400MHz DDR4 ECC Reg CL17 DIMM 1Rx4
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £5.30 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £1.60 | while stocks last
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £10.63 | in stock
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.43 | in stock
£100.67
saving £6.94
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Registered with parity
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 50 - 100
