Kingston 8GB 2400MHz DDR4 ECC CL17
Quicklinx: F8FGWS00 Mfr#: KSM24ES8/8ME
Kingston Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
Kingston Server Premier - DDR4 - module - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Single rank, unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Module Configuration
1024 X 72
Chips Organization
X8
Voltage
1.2 V
Lead Plating
Gold
