Your basket is empty
Kingston 8GB 2133MHz ECC Module
Quicklinx: C10WWS00 Mfr#: D1G72M150
Type: DDR4 SDRAM
Capacity: 8GB
Connection: DIMM 288-pin
Speed: 2133MHz
Data Integrity: ECC
Hurry, only 2 left in stock!
£66.61 ex VAT
£79.93 inc VAT
Express delivery Delivered on Wednesday
Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each brand name system. It’s guaranteed to be compatible and backed by a lifetime warranty and legendary Kingston reliability.
Kingston - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Unbuffered
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
Kingston 8GB 2133MHz ECC Module Bundle deal on Kingston 8GB 2133MHz ECC Module
£82.62
saving £8.87
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2133MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: CL15
Standard: PC4-17000
Brand: Kingston
Price Range Ex VAT: 50 - 100
