Your basket is empty
Kingston 8GB 1600MHz DDR3L ECC CL11 SODIMM
Quicklinx: BRGDWS00 Mfr#: KVR16LSE11/8
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 8 GB - SO-DIMM 204-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Dual rank, eight banks, On-Die Termination (ODT), Serial Presence Detect (SPD), unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11 (11-11-11)
ECC
Module Configuration
1024 X 72
Voltage
1.35 / 1.5 V
Lead Plating
Gold
