Your basket is empty
Kingston 8GB 1600MHz DDR3L ECC CL11 DIMM 2Rx8 1.35V Hynix D
Quicklinx: CFS2WS00 Mfr#: KVR16LE11/8HD
£51.13 ex VAT
£61.35 inc VAT
Kingston ValueRAM Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With ValueRAM Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
Kingston ValueRAM Server Premier - DDR3L - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz ( PC3L-12800 )
Latency Timings
CL11 ( 11-11-11 )
Temperature monitoring, dual rank, eight banks, On-Die Termination (ODT), Low Voltage , unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 ( 11-11-11 )
ECC
Module Configuration
1024 X 72
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Brand: Kingston
Price Range Ex VAT: 50 - 100
