Your basket is empty
Kingston 8GB 1600MHz DDR3 Non-ECC CL9 DIMM Kit of 2 XMP HyperX Savage
Quicklinx: 9QN1WS00 Mfr#: HX316C9SRK2/8
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
More than 50 in stock
£49.30 ex VAT
£59.16 inc VAT
Standard delivery Delivered within 3-5 working days
Marketing description is not available.
HyperX Savage - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9 ( 9-9-9 )
Single rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, red heat spreader, low profile heat spreader, asymmetrical heatspreader , unbuffered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL9 ( 9-9-9 )
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
Colour Category
Red
Kingston 8GB 1600MHz DDR3 Non-ECC CL9 DIMM Kit of 2 XMP HyperX Savage Bundle deal on Kingston 8GB 1600MHz DDR3 Non-ECC CL9 DIMM Kit of 2 XMP HyperX Savage
£65.62
saving £7.64
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-12800
Brand: Kingston
Price Range Ex VAT: 0 - 50
