Your basket is empty
Kingston 8GB 1333MHz DDR3 Non-ECC CL9 DIMM SR x8 (Kit of 2)
Quicklinx: CFTGWS00 Mfr#: KVR13N9S8HK2/8
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1333MHz
Data Integrity: Non-ECC
£51.39 ex VAT
£61.66 inc VAT
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9
Non-ECC
Module Configuration
512 x 64
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Kingston 8GB 1333MHz DDR3 Non-ECC CL9 DIMM SR x8 (Kit of 2) Bundle deal on Kingston 8GB 1333MHz DDR3 Non-ECC CL9 DIMM SR x8 (Kit of 2)
£64.88
saving £7.22
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1333MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-10600
Brand: Kingston
Price Range Ex VAT: 50 - 100
