HyperX Impact Black 8GB (2x4GB) DDR4 2400MHz CL14 SODIMM Memory
Quicklinx: BMK9WS00 Mfr#: HX424S14IBK2/8
Powerful SO-DIMM performance optimized for Intel's 100 series chipset.
Make an Impact in your game with powerful HyperX Impact DDR4 SO-DIMM. It automatically overclocks to the highest frequency published, up to 2666 MHz, without the need to adjust system BIOS settings, to support platforms that use Intel's CPU technologies. You get instant top-level performance with lower voltage that helps your system run cooler, quieter and more efficiently. All you'll ever miss is lag time.
HyperX Impact DDR4 has a slim form for easy installation in slim or ultra-slim notebooks and features a sleek design with a matching PCB that adds an aggressive look.
HyperX Impact - DDR4 - kit - 8 GB: 2 x 4 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL14 (14-14-14)
Single rank, On-Die Termination (ODT), dual channel, Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Limited lifetime warranty (Russia - 10 years)
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
SO-DIMM 260-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL14 (14-14-14)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.2 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL13 - 13-13-13 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL14 - 14-14-14
