HyperX HX421S13IBK2/8 is a kit of two 512M x 64-bit (4GB) DDR4-2133 CL13 SDRAM (Synchronous DRAM) 1Rx8, memory modules, based on eight 512M x 8-bit DDR4 FBGA components. Total kit capacity is 8GB. Each module kit supports Intel® Extreme Memory Profiles (Intel® XMP) 2.0. This module has been tested to run at DDR4-2133 at a low latency timing of 13-13-13 at 1.2V.
- HyperX Impact - DDR4 - kit - 8 GB: 2 x 4 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL13 (13-13-13)
- Single rank, On-Die Termination (ODT), dual channel, Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL13 (13-13-13)
- Non-ECC
- Module Configuration
- 512 x 64
- Chips Organization
- 512 x 8
- Voltage
- 1.2 V
