Get in the game with HyperX FURY. Even newbies get up to speed fast, since FURY automatically recognises its host platform and automatically overclocks to the highest frequency published - up to 1866MHz - providing plenty of power for your next deathmatch. Affordably priced, FURY's asymmetric heat spreader design is available in black, blue, red and- for the first time in the HyperX line -white, with a black PCB. It's 100 per cent tested and backed by a lifetime warranty and free technical support.
- Asymmetric heat spreader for stylish heat dissipation
- Compatible with Intel and AMD platforms
Features & Benefits
- Unique -- tested with all popular brands of motherboards
- Easy to install -- Plug-and-Play functionality
- Automatic overclocking -- reach faster speeds and higher capacities just by installing the memory, no adjustments in BIOS needed
- Reliable -- 100 per cent factory tested
- Lifetime warranty, free technical support
- Capacity 8GB
- Frequency speed 1600MHz
- CAS latency 10-10-10-30
- Voltage 1.5V
- Operating temperature 0C to 85C
- Storage temperature -55C to 100C
- Dimensions 133.35mm x 32.8mm
- Compatible with P55, H67, P67, Z68, Z77, Z87 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- HyperX FURY - DDR3 - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL10 (10-10-10-30)
- Black PCB, FURY asymmetric heatspreader, unbuffered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.29
- Speed
- Latency Timings
- Non-ECC
- Module Configuration
- 1024 x 64
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Colour Category
- Blue
