Your basket is empty
Kingston 64GB SDHC UHS-I Speed Class 3 Flash Card
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 98TYWS00 Mfr#: SDA3/64GB
Move to faster performance with Kingston's SDHC/SDXC UHS-I U3 Flash card. With speeds of 90MB/s read and 80MB/s write, it reads up to 9x faster and writes up to 8x faster than standard Class 10 SD cards. It meets the SD Association's latest specification release, UHS-I U3 (Ultra High-Speed Bus, Speed Class 3), which guarantees performance of at least 30MB/s and enough bandwidth to record and playback 4K2K video without interruption.
Users can capture cinema-quality Full HD (1080p), Ultra HD (2160p), 3D and 4K2K videos on high-performance cameras such as Digital Single Lens Reflex (D-SLR), Digital Single Lens Mirrorless (D-SLM), camcorders and video cameras. It's ideal for television recordings as well as live broadcasts, plus it lets you edit files faster and provides faster upload times, especially when using USB 3.0 card readers. Its higher sustained write speeds ensure video integrity by reducing stutter and allow photographers to shoot in continuous burst mode.
Kingston - flash memory card - 64 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
UHS Class 3
Supply Voltage
3.3 V
Flash memory card
Storage Capacity
64 GB
Compatibility
Non-specific
SD Speed Class
UHS Class 3
Read Rate
Up to 90 MB/s
Write Rate
Up to 80 MB/s
Supply Voltage
3.3 V
Write protection switch
ISO 9001:2008
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
