It's easy to find the Flash memory, USB drives and accessories to maximize your mobile device. Kingston Flash memory products feature fast speeds, large capacities and impressive performance. Kingston Flash memory - it's for you.
- Kingston Multi-Kit / Mobility Kit - flash memory card - 64 GB - microSDXC UHS-I
- Product Type
- Flash memory card
- Bundled with
- USB Reader
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 64 GB
- Speed Rating
- UHS Class 1 / Class10
- Included Memory Adapter
- microSDXC to SD adapter
- OS Required
- Linux 2.6.x or later, Microsoft Windows Vista, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1
- Limited lifetime warranty
- Product Type
- Flash memory card
- Bundled with
- USB Reader
- Storage Capacity
- 64 GB
- Speed Class
- Form Factor
- OS Required
- Limited warranty - lifetime
- 11 mm
- 15 mm
- Thickness
- 1 mm
- -25 °C
- 85 °C
