Product
Kingston 64GB DDR4 LRDIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2V Load-Reduced ECC
Quicklinx: CB41WS00 Mfr#: KTL-TS424LQ/64G
Type: DDR4 SDRAM
Capacity: 64GB
Connection: LRDIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
£631.52 ex VAT
£757.82 inc VAT
Kingston manufacture the most reliable memory you can buy for a Lenovo Server. Kingstons legendary reputation is built around reliable memory, that will power your Lenovo server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Lenovo compatible memory module.
  • for Lenovo ThinkServer RD350; RD450; TD350
Kingston - DDR4 - 64 GB - LRDIMM 288-pin - LRDIMM
RAM memory
64 GB
Memory Type
DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Quad rank, Load-Reduced
Voltage
1.2 V
Lead Plating
Gold
Lenovo 4X70G88321
Limited lifetime warranty (Russia - 10 years)
Lenovo ThinkServer RD350 70QK, 70QL, 70QM, 70QN; RD450 70Q9, 70QQ, 70QR, 70QS, 70QW; RD550 70R5, 70S6; RD650 70RB; TD350 70DG, 70DH, 70DJ, 70DK, 70DL, 70DM, 70DN, 70DQ
64 GB
Upgrade Type
System specific
Lenovo 4X70G88321
DRAM
DDR4 SDRAM
LRDIMM 288-pin
Speed
Latency Timings
CL17
ECC
Module Configuration
8192 x 72
Voltage
1.2 V
Lead Plating
Gold
Lenovo ThinkServer RD350 70QK, 70QL, 70QM, 70QN , Lenovo ThinkServer RD450 70Q9, 70QQ, 70QR, 70QS, 70QW , Lenovo ThinkServer RD550 70R5, 70S6 , Lenovo ThinkServer RD650 70RB , Lenovo ThinkServer TD350 70DG, 70DH, 70DJ, 70DK, 70DL, 70DM, 70DN, 70DQ
Type: DDR4 SDRAM
Capacity: 64GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Load-Reduced
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 500 - 750
