Product
Kingston 64GB DDR4 LRDIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2V Load-Reduced ECC
Quicklinx: CB40WS00 Mfr#: KTH-PL424LQ/64G
Type: DDR4 SDRAM
Capacity: 64GB
Connection: LRDIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
10 in stock
£466.56 ex VAT
£559.87 inc VAT
Kingston manufacture the most reliable memory you can buy for a HP Compaq Server. Kingstons legendary reputation is built around reliable memory, that will power your HP Compaq server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this HP Compaq compatible memory module.
Kingston - DDR4 - 64 GB - LRDIMM 288-pin - LRDIMM
RAM memory
64 GB
Memory Type
DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Quad rank, Load-Reduced
Voltage
1.2 V
Lead Plating
Gold
HP 805358-B21, HP 819413-001
Limited lifetime warranty (Russia - 10 years)
HPE Apollo 4200 Gen9, 4520 Gen9; ProLiant BL660c Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL560 Gen9, DL580 Gen9, DL80 Gen9, WS460c Gen9, XL230a Gen9, XL250a Gen9, XL260a Gen9, XL270d Gen9, XL2x260; SimpliVity 380 Gen9; Synergy 480 Gen9, 620 Gen9, 660 Gen9, 680 Gen9
64 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
LRDIMM 288-pin
Speed
Latency Timings
CL17
ECC
Module Configuration
8192 x 72
Voltage
1.2 V
Lead Plating
Gold
HPE Apollo 4200 Gen9, 4520 Gen9 , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, BL660c Gen9, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL360 Gen9 Special Server, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380 Gen9 Scale-up SAP HANA Tailored Datacenter Integration Compute Block, DL380 Gen9 Special, DL388 Gen9, DL388 Gen9 Base, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL580 Gen9, DL580 Gen9 Base, DL580 Gen9 Database, DL580 Gen9 High Performance, DL580 Gen9 SAP HANA Scale-out Base Configuration, DL80 Gen9 Entry, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL230a Gen9, XL230a Gen9 Compute Tray, XL230a Gen9 Compute Tray (12G), XL230a Gen9 Compute Tray (6G), XL230a Gen9 NHP Compute Tray (12G), XL250a Gen9, XL250a Gen9 Accelerator Tray, XL260a Gen9, XL260a Gen9 Compute Tray, XL270d Gen9, XL2x260w , HPE SimpliVity 380 Gen9 Node , HPE Synergy 480 Gen9 Compute Module, 480 Gen9 Expanded Storage Compute Module, 620 Gen9 2S-EX Base Compute Module, 620 Gen9 2S-EX Performance Compute Module, 660 Gen9 Base Compute Module, 660 Gen9 Compute Module, 660 Gen9 Entry Compute Module, 660 Gen9 Expanded Storage Compute Module, 660 Gen9 Performance Compute Module, 680 Gen9 4S-EX Base Compute Module, 680 Gen9 4S-EX Performance Compute Module
Type: DDR4 SDRAM
Capacity: 64GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Load-Reduced
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 300 - 500
