Kingston manufacture the most reliable memory you can buy for a Dell Server. Kingstons legendary reputation is built around reliable memory, that will power your Dell server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Dell compatible memory module.
- For Dell PowerEdge FC630, M830, R630, R730, R930
- Kingston - DDR4 - 64 GB - LRDIMM 288-pin
- Product Type
- RAM memory
- Capacity
- 64 GB
- Memory Type
- DDR4 SDRAM - LRDIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL17
- Quad rank, Load-Reduced
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- DELL A8711890
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Dell PowerEdge C4130, FC630, FC830, M630, M830, R630, R730, R730xd, R930, T630; Precision Rack 7910; Precision Tower 7910
- Capacity
- 64 GB
- Upgrade Type
- System specific
- DELL A8711890
- DRAM
- Technology
- DDR4 SDRAM
- Form Factor
- LRDIMM 288-pin
- Speed
- Latency Timings
- CL17
- ECC
- Module Configuration
- 8192 x 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
- Dell PowerEdge C4130, FC630, FC830, M630, M830, R630, R730, R730xd, R930, T630 , Dell Precision Rack 7910 , Dell Precision Tower 7910
