Kingston 64GB Canvas Go SDXC Card
Quicklinx: DS7XWS00 Mfr#: SDG/64GB
Type: SDXC UHS-I Memory Card
Capacity: 64GB
SD Speed Class: Video Class V30 / UHS-I U3 / Class10
£10.19 ex VAT
£12.22 inc VAT
Kingston's Canvas Go! microSD card is designed to be on-the-go, making it ideal for filming life's adventures in 1080p or even 4K. You can be confident that your memories will be safe when documenting the next journey on your GoPro, drone, or dash cam.
  • Made for movement
    Capture your latest hike, underwater adventure, or that sweeping landscape using this UHS-I U3 card.
  • 4K video
    The advanced UHS-I U3 interface makes the card ideal for cinema-quality 4K video.
  • Get your memories faster
    Transfer and edit your memories quicker thanks to the incredible 9x read speeds over traditional Class 10 SD cards.
Kingston Canvas Go! - flash memory card - 64 GB - SDXC UHS-I
Flash memory card
Storage Capacity
64 GB
Speed Rating
Flash memory card
Storage Capacity
64 GB
Compatibility
Non-specific
SD Speed Class
Read Rate
Up to 90 MB/s
Write Rate
Up to 45 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
Capacity: 64GB
Brand: Kingston
Price Range Ex VAT: 0 - 50
