Product
Brand
Kingston 64GB 3000MHz DDR4 CL16 DIMM (Kit of 4) XMP HyperX Predator
Quicklinx: BSX3WS00 Mfr#: HX430C16PBK4/64
Prey on the competition.
Game play just got more aggressive with extreme speeds and low latencies for unbeatable DDR4 performance. HyperX® Predator DDR4 complements Intel’s 2, 4, 6 or 8 core processors for faster video editing, 3D rendering, gaming and AI processing. It’s XMP ready and XMP certified and available in CL12–CL16 latencies and in 16GB, 32GB and 64GB kits in speeds of up to 3000MHz. 16GB modules in kits of 2 and 4 are also available.
HyperX Predator DDR4’s Intel XMP-ready profiles are optimised for Intel 100 series and X99 series motherboards. Hand-tuned XMP profiles are built directly into the modules, so users can easily overclock their platforms by simply selecting a profile, with no need for manual timing adjustments in BIOS.
Predator DDR4 keeps its cool while gaming, with a low 1.2V or 1.35V only for all parts. The result is lower power consumption over DDR3 memory, for a cooler, quieter, more reliable system.
Stand out from the crowd and maximise heat dissipation with Predator’s signature tall heat sink, now in black. Its style complements the design of the latest PC hardware. HyperX Predator DDR4 is backed by a lifetime warranty, free technical support, and the reliability and expertise that make HyperX unbeatable.
  • Extreme speeds and low latencies for unbeatable performance
  • Intel XMP-ready profiles optimised for Intel 100 series and X99 series motherboards
  • Lower power consumption than DDR3
  • Tall heat spreader design for greater heat dissipation.
HyperX Predator - DDR4 - 64 GB: 4 x 16 GB - DIMM 288-pin
RAM memory
64 GB: 4 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL16 (16-16-16)
Temperature monitoring, dual rank, black heatsink, On-Die Termination (ODT), Serial Presence Detect (SPD), tall heatsink, low profile heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
64 GB: 4 x 16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
2.17
Speed
Latency Timings
CL16 (16-16-16)
Non-ECC
Module Configuration
2048 x 64
Chips Organization
1024 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 3000 MHz - 1.35 V - CL16 - 16-16-16
Colour Category
