Your basket is empty
Kingston 64GB 2133MHz DDR4 CL14 SODIMM (Kit of 4) HyperX Impact
Quicklinx: BZN6WS00 Mfr#: HX421S14IBK4/64
Type: DDR4 SDRAM
Capacity: 64GB
Connection: SO-DIMM 260-pin
Speed: 2133MHz
Data Integrity: Non-ECC
24 in stock
£345.07 ex VAT
£414.08 inc VAT
Impact your game with HyperX® Impact DDR4 SODIMM. XMP-ready in capacities of up to 64GB HyperX Impact DDR4 automatically overclocks to the highest frequency published, up to 2400MHz, without the need to adjust system BIOS settings, to support platforms that use Intel’s latest CPU technologies. Run cool, quiet and efficiently with instant top-level performance and lower voltage. HyperX Impact DDR4 has a slim form factor and features a sleek black design with matching PCB.
Kingston HyperX Impact - DDR4 - 64 GB : 4 x 16 GB - SO-DIMM 260-pin
64 GB : 4 x 16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Module Height (inch)
1.18
Speed
2133 MHz ( PC4-17000 )
Latency Timings
CL14 ( 14-14-14 )
Data Integrity Check
Non-ECC
Dual rank, On-Die Termination (ODT), dual channel, Black PCB, quad channel, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0) , unbuffered
Module Configuration
2048 x 64
Chips Organization
1024 x 8
Voltage
1.2 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP 2.0) - 2133 MHz - 1.2 V - CL14 - 14-14-14
Colour Category
Limited lifetime warranty ( Russia - 10 years )
Kingston 64GB 2133MHz DDR4 CL14 SODIMM (Kit of 4) HyperX Impact Bundle deal on Kingston 64GB 2133MHz DDR4 CL14 SODIMM (Kit of 4) HyperX Impact
£361.39
saving £7.71
Type: DDR4 SDRAM
Capacity: 64GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL14
Standard: PC4-17000
Brand: Kingston
Price Range Ex VAT: 300 - 500
