Your basket is empty
Kingston 64 GB (8 x 8 GB)  FB-DIMM 240-pin DDR2 667 MHz / PC2-5300 Fully Buffered ECC
Quicklinx: 6DHZWS00 Mfr#: KTH-XW667/64G
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - 64 GB: 8 x 8 GB - FB-DIMM 240-pin
RAM memory
64 GB: 8 x 8 GB
Memory Type
DDR2 SDRAM - FB-DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Fully Buffered
HP 495604-B21
Limited lifetime warranty (Germany, Austria and France - 10 years)
HPE ProLiant BL460c, BL460c G5, BL480c, BL680c G5, DL140 G3, DL160 G5, DL360 G5, DL380 G5, DL580 G5; Workstation xw8600
64 GB: 8 x 8 GB
Upgrade Type
System specific
HP 495604-B21
DRAM
DDR2 SDRAM
FB-DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC
Fully Buffered
Compatible Slots
8 x memory - FB-DIMM 240-pin
HPE ProLiant BL460c, BL460c G5, BL480c, BL680c G5, DL140 G3, DL160 G5, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 High Efficiency, DL360 G5 Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Availability Storage Server, DL380 G5 High Efficiency, DL380 G5 High Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance , HPE Workstation xw8600
