Now mS200 mSATA solid-state drive offers a cost-effective performance boost with dual-drive option that allows room for adding high-capacity storage. Ideal for system builders, OEMs, and enthusiasts, the mS200's ruggedly-cool, miniscule form factor is eight times smaller than a traditional 2.5" hard drive, making it perfect for notebooks, tablets and Ultrabooks.
- Kingston SSDNow mS200 - SSD - 60 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 60 GB
- Form Factor
- mSATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, TRIM support, Smart Response Technology, SandForce SF-2241 controller, S.M.A.R.T.
- 30 mm x 50.88 mm
- 6.86 g
- 3-year warranty
- Capacity
- 60 GB
- Form Factor
- mSATA
- Interface
- SATA 6Gb/s
- 30 mm
- 50.88 mm
- 6.86 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 14000 IOPS
- 4KB Random Write
- 77000 IOPS
- Maximum 4KB Random Write
- 79000 IOPS
- Maximum 4KB Random Read
- 86000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 52 pin mini-SATA
- Compatible Bay
- mSATA
- Power Consumption
- 1.8 Watt (active) , 0.4 Watt (idle)
- ISO 9001:2008
- Limited warranty - 3 years , Technical support
- 0 °C
- 70 °C
