Kingston 512MB SODIMM DDR
Quicklinx: 20TVWS00 Mfr#: KTD-INSP8200/512
Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for Dell Inspiron 8200, Dell Latitude C840.
Kingston - DDR - module - 512 MB - SO-DIMM 200-pin - 266 MHz / PC2100 - unbuffered
Memory module
512 MB
Memory Type
DDR SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
266 MHz (PC2100)
Latency Timings
CL2.5
Unbuffered
Voltage
2.5 V
Lead Plating
Gold
DELL 311-1356, DELL 311-1683, DELL A0098271
Limited lifetime warranty (Germany, Austria and France - 10 years)
Dell Inspiron 1100, 1150, 300m, 4150, 500m, 5100, 510m, 600m, 8200, 8500; Latitude 100L, C540, C640, C840, D400, D500, D600, D800, X300; Precision M50; SmartStep 200N, 250N
512 MB
Upgrade Type
System specific
DRAM memory module
DDR SDRAM
SO-DIMM 200-pin
Speed
266 MHz (PC2100)
Latency Timings
CL2.5
Non-ECC
Unbuffered
Module Configuration
64 x 64
Voltage
2.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 200-pin
Dell Inspiron 1100, 1150, 300m, 4150, 500m, 5100, 510m, 600m, 8200, 8500 , Dell Latitude 100L, C540, C640, C840, D400, D500, D600, D800, X300 , Dell Precision M50 , Dell SmartStep 200N, 250N
