Kingston 4GB DDR4 2400MHz SO-DIMM CL17 Memory
Clearance
Limited Time Offer
Quicklinx: D7QCWS00 Mfr#: KCP424SS6/4
Type: DDR4 SDRAM
Capacity: 4GB
Connection: SO-DIMM 260-pin
Speed: 2400MHz
Data Integrity: Non-ECC
£25.00 ex VAT
£30.00 inc VAT
Kingston - DDR4 - 4 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - CL17 - 1.2 V - unbuffered - non-ECC
Kingston - DDR4 - 4 GB - SO-DIMM 260-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Single rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL17
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 16
Voltage
1.2 V
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 0 - 50
