Kingston 4GB DDR4-2400MHz ECC Module
Quicklinx: CWKYWS00 Mfr#: KTH-PL424E/4G
Kingston 4GB DDR4 KTH-PL424E/4G HP 2400MHz ECC Unbuffered RAM Memory DIMM.
Kingston - DDR4 - 4 GB - DIMM 288-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Unbuffered
Module Configuration
512 x 72
Voltage
1.2 V
Lead Plating
Gold
