Kingston 4GB DDR4-2400MHz ECC Module
Quicklinx: CWKRWS00 Mfr#: KCP424ES8/4
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
£44.53 ex VAT
£53.43 inc VAT
Kingston 4GB DDR4 KCP424ES8/42400MHz ECC Unbuffered RAM Memory DIMM
Kingston - DDR4 - 4 GB - DIMM 288-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Unbuffered
Module Configuration
512 x 72
Voltage
1.2 V
Lead Plating
Gold
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 0 - 50
