Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each brand name system. It’s guaranteed to be compatible and backed by a lifetime warranty and legendary Kingston reliability.
- Kingston - DDR4 - module - 4 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Unbuffered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Lenovo 4X70K14183
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Lenovo ThinkStation P310 30AS, 30AT, 30AU, 30AV
- Capacity
- 4 GB
- Upgrade Type
- System specific
- Lenovo 4X70K14183
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- ECC
- Unbuffered
- Module Configuration
- 512 x 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
