Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR3L - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Low Voltage, unbuffered
- Voltage
- 1.35 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Lenovo 0C19499
- Limited lifetime warranty
- Designed For
- Lenovo ThinkServer RS140 70F2, 70F3, 70F8, 70F9; TD340 70B5, 70B6, 70B7; TS130 1098, 1100, 1105, 1106; TS140 70A0, 70A1, 70A4, 70A5; TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441; TS440 70AL, 70AM, 70AN, 70AQ
- Capacity
- 4 GB
- Upgrade Type
- System specific
- Lenovo 0C19499
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL11
- ECC
- Module Configuration
- 512 x 72
- Voltage
- 1.35 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Lenovo ThinkServer RS140 70F2, 70F3, 70F8, 70F9 , Lenovo ThinkServer TD340 70B5, 70B6, 70B7 , Lenovo ThinkServer TS130 1098, 1100, 1105, 1106 , Lenovo ThinkServer TS140 70A0, 70A1, 70A4, 70A5 , Lenovo ThinkServer TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441 , Lenovo ThinkServer TS440 70AL, 70AM, 70AN, 70AQ
