Your basket is empty
Kingston 4GB DDR3 DIMM 240-pin 1600 MHz/PC3-12800 CL11 1.5 V unbuffered ECC Memory Module
Quicklinx: B27YWS00 Mfr#: KTD-PE316ES/4G
Type: DDR3 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: ECC
5 in stock
£35.32 ex VAT
£42.38 inc VAT
Standard delivery Delivered within 3-5 working days
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
Dell PowerEdge C5220, M420, M620, R210 II, R320, R620, R715, R720, R720xd, T110 II, T20, T20 Mini Tower Server, T320, T620; PowerVault NX3200; Precision T1700; Precision Fixed Workstation T1650, T3600, T3600 Base, T3600 Essential, T5600, T5600 Advanced, T5600 Base, T5600 Essential
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
512 x 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Dell PowerEdge C5220, M420, M620, R210 II, R320, R620, R715, R720, R720xd, T110 II, T20, T20 Mini Tower Server, T320, T620 , Dell PowerVault NX3200 , Dell Precision T1700 , Dell Precision Fixed Workstation T1650, T3600, T3600 Base, T3600 Essential, T5600, T5600 Advanced, T5600 Base, T5600 Essential
Kingston 4GB DDR3 DIMM 240-pin 1600 MHz/PC3-12800 CL11 1.5 V unbuffered ECC Memory Module Bundle deal on Kingston 4GB DDR3 DIMM 240-pin 1600 MHz/PC3-12800 CL11 1.5 V unbuffered ECC Memory Module
£50.39
saving £6.92
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1600MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-12800
Brand: Kingston
Price Range Ex VAT: 0 - 50
