Your basket is empty
Kingston 4GB 2133MHz DDR4 ECC Reg CL15 DIMM SR x8 w/TS
Quicklinx: B9GLWS00 Mfr#: KVR21R15S8/4
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: 2133MHz
Data Integrity: ECC
1 in stock
£34.89 ex VAT
£41.86 inc VAT
Standard delivery Delivered within 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL15 (15-15-15)
ECC
Module Configuration
512 x 72
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
RoHS
Kingston 4GB 2133MHz DDR4 ECC Reg CL15 DIMM SR x8 w/TS Bundle deal on Kingston 4GB 2133MHz DDR4 ECC Reg CL15 DIMM SR x8 w/TS
£56.08
saving £14.13
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 2133MHz
Data Integrity: ECC
Registered/Buffered: Registered with parity
CAS Latency: CL15
Standard: PC4-17000
Brand: Kingston
Price Range Ex VAT: 0 - 50
