Product
Brand
Kingston 4GB 1600MHz Reg ECC 1Rx8 Single Rank Memory Module
Quicklinx: 9CZCWS00 Mfr#: KTH-PL316S8/4G
Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. Kingston ValueRAM is your best source for industry-standard memory to maximise the performance and productivity of your system. Built with A-grade components only, Kingston ValueRAM memory modules come with a lifetime warranty.
Kingston - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Single rank, registered
Voltage
1.5 V
Lead Plating
Gold
HPE ProLiant BL2x220c G6, BL2x220c G7, BL460c G7, BL465c G7, BL465c Gen8, BL490c G7, BL685c G7, DL165 G7, DL170E G6, DL320 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL585 G7, ML330 G6, ML350 G6, ML370 G6, SL160s G6, SL165s G7, SL165z G7, SL170s G6, SL390s G7, WS460c G6; Workstation z600
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL2x220c G7, BL460c G7, BL465c Gen8, BL490c G7, BL685c G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL170E G6, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Special Server, DL370 G6 High Performance, DL370 G6 Special Server, DL380 G6, DL380 G7 Special Server, DL585 G7 Performance, ML370 G6 Special Server, SL160s G6, SL160s G6 Base, SL160s G6 Entry, SL160s G6 Performance, SL165s G7, SL165s G7 Base, SL165s G7 Entry, SL165s G7 Performance, SL170s G6 1U Left Half Width tray, SL170s G6 1U Right Half Width tray, SL170s G6 Base 1U Left Half Width tray, SL170s G6 Base 1U Right Half Width tray, SL170s G6 Base Left Half Width tray, SL170s G6 Entry 1U Left Half Width tray, SL170s G6 Entry 1U Right Half Width tray, SL170s G6 Performance 1U Left Half Width tray, SL170s G6 Performance 1U Right Half Width tray, SL390s G7, SL390s G7 1U Left Half Width tray, SL390s G7 1U Left Tray Node Server, SL390s G7 1U Right Half Width tray, SL390s G7 1U Right Tray Node Server, SL390s G7 2U Left Half Tray Node Server, SL390s G7 2U Right Half Width tray, SL390s G7 4U Left Half Width tray, SL390s G7 4U Left Tray Node Server, SL390s G7 4U Right Half Width tray, SL390s G7 4U Right Tray Node Server, SL390s G7 Base 1U left Half Width tray, SL390s G7 Base 1U Right Half Width tray, SL390s G7 Base 2U Left Half Width tray, SL390s G7 Base 2U Right Half Width tray, SL390s G7 Base 4U Left Half Width tray, SL390s G7 Base 4U Right Half Width tray, SL390s G7 Entry 1U Left Half Width tray, SL390s G7 Entry 1U Right Half Width tray, SL390s G7 Entry 2U Left Half Width tray, SL390s G7 Entry 2U Right Half Width tray, SL390s G7 Performance 1U left Half Width tray, SL390s G7 Performance 1U Right Half Width tray, SL390s G7 Performance 2U Left Half Width tray, SL390s G7 Performance 2U Right Half Width tray, SL390s G7 Performance 4U Left Half Width tray, SL390s G7 Performance 4U Right Half Width tray , HPE Workstation z600
