Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. Kingston ValueRAM is your best source for industry-standard memory to maximise the performance and productivity of your system. Built with A-grade components only, Kingston ValueRAM memory modules come with a lifetime warranty.
- Kingston - DDR3 - 4 GB - DIMM 240-pin
- Product Type
- RAM memory
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Single rank, registered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty
- Designed For
- Dell PowerEdge C1100, C2100, C6100, C6105, M610, M610x, M620, M710, M710HD, R310, R410, R415, R510, R515, R610, R620, R710, R715, R720, R720xd, R815, R910, T310, T410, T610, T620, T710; PowerVault DL2100, NX3000, NX3100; Precision T5500, T7500; Precision Fixed Workstation R5500
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL11
- ECC
- Module Configuration
- 512 x 72
- Chips Organization
- X8
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Dell PowerEdge C1100, C2100, C6100, C6105, M610, M610x, M620, M710, M710HD, R310, R410, R415, R510, R515, R610, R620, R710, R715, R720, R720xd, R815, R910, T310, T410, T610, T620, T710 , Dell PowerVault DL2100, NX3000, NX3100 , Dell Precision T5500, T7500 , Dell Precision Fixed Workstation R5500
