Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR3 - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Single rank, unbuffered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty
- Designed For
- Lenovo ThinkServer TS130; TS430; ThinkStation C20; C20x; C30; D20; D30; E30; E31; E32; S30
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL11
- ECC
- Module Configuration
- 512 x 72
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Lenovo ThinkServer TS130 1098, 1100, 1105, 1106 , Lenovo ThinkServer TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441 , Lenovo ThinkStation C20 4262, 4263, 4265 , Lenovo ThinkStation C20x 4266, 4269, 4272 , Lenovo ThinkStation C30 1095, 1097, 1136, 1137 , Lenovo ThinkStation D20 4155, 4158, 4218 , Lenovo ThinkStation D30 4223, 4229, 4352, 4353, 4354 , Lenovo ThinkStation E30 7782, 7783, 7821, 7824 , Lenovo ThinkStation E31 2551, 2552, 2553, 2555, 3688, 3690, 3691, 3695 , Lenovo ThinkStation E32 30A0, 30A1, 30A2, 30A3 , Lenovo ThinkStation S30 0567, 0568, 0569, 0606, 4351, 4352
