Your basket is empty
Kingston 4GB 1600MHZ DDR3L ECC CL11
Quicklinx: 9YQ3WS00 Mfr#: KVR16LE11L/4
Type: DDR3L SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: ECC
11 in stock
£27.50 ex VAT
£33.00 inc VAT
Standard delivery Delivered within 3-5 working days
Marketing description is not available.
Kingston - DDR3L - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin very low profile
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
Speed
Latency Timings
CL11
ECC
Unbuffered
Module Configuration
512 x 72
Voltage
1.35 V
Compatible Slots
Memory - DIMM 240-pin
Kingston 4GB 1600MHZ DDR3L ECC CL11 Bundle deal on Kingston 4GB 1600MHZ DDR3L ECC CL11
£43.82
saving £8.65
Type: DDR3L SDRAM
Capacity: 4GB
Speed: 1600MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-12800
Brand: Kingston
Price Range Ex VAT: 0 - 50
