Your basket is empty
Kingston 4GB 1600MHz DDR3L ECC CL11 DIMM 1Rx8 1.35V Hynix D
Quicklinx: CFS3WS00 Mfr#: KVR16LE11S8/4HD
Type: DDR3L SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: ECC
11 in stock
£31.02 ex VAT
£37.22 inc VAT
Standard delivery Delivered within 3-5 working days
Kingston ValueRAM Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With ValueRAM Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
Kingston ValueRAM Server Premier - DDR3L - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Temperature monitoring, single rank, eight banks, On-Die Termination (ODT), Low Voltage, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
ECC
Module Configuration
512 x 72
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
Kingston 4GB 1600MHz DDR3L ECC CL11 DIMM 1Rx8 1.35V Hynix D Bundle deal on Kingston 4GB 1600MHz DDR3L ECC CL11 DIMM 1Rx8 1.35V Hynix D
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £5.35 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £1.60 | while stocks last
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £10.63 | in stock
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.47 | in stock
£47.07
saving £7.01
Type: DDR3L SDRAM
Capacity: 4GB
Speed: 1600MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3L-12800
Brand: Kingston
Price Range Ex VAT: 0 - 50
