Your basket is empty
Kingston 4GB (1x4GB) HyperX Savage 2400MHz DDR4 CL12 XMP
Quicklinx: BMKMWS00 Mfr#: HX424C12SB/4
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: Non-ECC
Hurry, only 2 left in stock!
£22.06 ex VAT
£26.47 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
HyperX Savage DDR4 memory is an unbeatable combination of fast speeds and aggressive timings to complement Intel's 2, 4, 6 or 8 core processors for faster video editing, 3D rendering, gaming and AI processing. With speeds up to 3000 MHz and latencies of CL12-CL15, it's optimized for Intel's Z170 and X99 chipsets and features easy overclocking with no need for manual timing adjustments in BIOS.
HyperX Savage DDR4 memory has lower power consumption than DDR3. Its asymmetrical, stylish, die-cast aluminum heat spreader has a low profile to fit under oversized CPU coolers and provide enhanced thermal dissipation to keep your system cooler as it complements the look of the PC hardware and helps you stand out from the "square" crowd. The heat spreader and matching PCB are made from quality aluminum material and feature a diamond-cut finish.
Attack the competition with style and confidence.
HyperX Savage - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL12 (12-13-13)
Single rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL12 (12-13-13)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2133 MHz - 1.2 V - CL13 - 13-13-13 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.35 V - CL12 - 12-13-13
Colour Category
Kingston 4GB (1x4GB) HyperX Savage 2400MHz DDR4 CL12 XMP Bundle deal on Kingston 4GB (1x4GB) HyperX Savage 2400MHz DDR4 CL12 XMP
£38.38
saving £8.65
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL12
Standard: PC4-19200
Brand: Kingston
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
