ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
- Kingston ValueRAM - DDR3L - kit - 48 GB: 3 x 16 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - registered with parity
- Product Type
- Memory kit
- Capacity
- 48 GB: 3 x 16 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3L-12800)
- Latency Timings
- CL11 (11-11-11)
- Temperature monitoring, dual rank, eight banks, On-Die Termination (ODT), triple channel, Low Voltage, registered with parity
- Voltage
- 1.35 / 1.5 V
- Lead Plating
- Gold
- Pricing Type
- Intel Memory Validation Program
- Limited lifetime warranty
- Capacity
- 48 GB: 3 x 16 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL11 (11-11-11)
- ECC
- Module Configuration
- 2048 x 72
- Chips Organization
- 1024 x 4
- Voltage
- 1.35 / 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 3 x memory - DIMM 240-pin
- Pricing Type
