Kingston's SSD UV400 is powered by a four-channel Marvell controller for amazing speeds and higher performance. It dramatically improves the responsiveness of your existing system. Rugged and more reliable and durable, UV400 is built using flash memory so it's shock- and vibration-resistant and less likely to fail than a mechanical hard drive. Its ruggedness makes it ideal for notebooks and other mobile computing devices. It's the ideal hard drive replacement and can also replace a smaller SSD in your system to give you all the room you need.
High read/write speeds
Its high read/write speeds will not only increase performance but also breathe life into existing systems. -
Marvell controller
UV400 is powered by a four-channel controller that delivers impressive speeds with both compressible and incompressible data. It has a processor optimized for performance and endurance. -
Rugged reliability
UV400 is shock- and vibration-resistant for rugged reliability in notebooks and other mobile computing devices.
- Kingston UV400 Desktop/Notebook Upgrade Kit - solid state drive - 480 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 480 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5" (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, rugged, Marvell 88SS1074 controller
- 69.9 mm x 100 mm x 7 mm
- 57 g
- 3-year warranty
- Capacity
- 480 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.9 mm
- 100 mm
- 7 mm
- 57 g
Performance
- SSD Endurance
- 256 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 500 MBps (write)
- Maximum 4KB Random Write
- 35000 IOPS
- Maximum 4KB Random Read
- 90000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" or 3.5" (with included bay adapter)
- Power Consumption
- 0.693 Watt (average) , 0.672 Watt (idle) , 0.59 Watt (read) , 2.515 Watt (write)
- Included Accessories
- 3.5-inch bay adapter, 2.5" USB enclosure, 7mm to 9.5mm holder
- Cables Included
- 1 x Serial ATA cable - internal
- Mounting Kit
- Included
- Limited warranty - 3 years , Technical support
- 0 °C
- 70 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
