Kingston 480GB SSDNow UV400 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: C3MQWS00 Mfr#: SUV400S37/480G
Breathe new life into your system
Kingston’s SSDNow UV400 is powered by a four-channel Marvell controller for incredible speeds and higher performance compared to a mechanical hard drive. It dramatically improves the responsiveness of your existing system and is 10 times faster than a 7200RPM hard drive.
Rugged and more reliable and durable than a hard drive, UV400 is built using Flash memory so it’s shock and vibration-resistant and less likely to fail than a mechanical hard drive. Its ruggedness makes it ideal for notebooks and other mobile computing devices.
It’s the ideal hard drive replacement and can also replace a smaller SSD in your system to give you all the room you need.
• 10 times faster than a 7200RPM hard drive
• More reliable and durable than a hard drive
• Multiple capacities to meet your needs
  • High read/write speeds
    Its high read/write speeds will not only increase performance but also breathe life into existing systems.
  • Marvell controller
    UV400 is powered by a four-channel controller that delivers impressive speeds with both compressible and incompressible data. It has a processor optimized for performance and endurance.
  • Rugged reliability
    UV400 is shock- and vibration-resistant for rugged reliability in notebooks and other mobile computing devices.
Kingston SSDNow UV400 - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
NAND Flash Memory Type
Triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, rugged, Marvell 88SS1074 controller
69.9 mm x 100 mm x 7 mm
57 g
3-year warranty
480 GB
2.5"
SATA 6Gb/s
69.9 mm
100 mm
7 mm
57 g
Performance
SSD Endurance
256 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 500 MBps (write)
Maximum 4KB Random Write
35000 IOPS
Maximum 4KB Random Read
90000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.693 Watt (average) , 0.672 Watt (idle) , 0.59 Watt (read) , 2.515 Watt (write)
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
