Breathe new life into your system
Kingston’s SSDNow UV400 is powered by a four-channel Marvell controller for incredible speeds and higher performance compared to a mechanical hard drive. It dramatically improves the responsiveness of your existing system and is 10 times faster than a 7200RPM hard drive.
Rugged and more reliable and durable than a hard drive, UV400 is built using Flash memory so it’s shock and vibration-resistant and less likely to fail than a mechanical hard drive. Its ruggedness makes it ideal for notebooks and other mobile computing devices.
It’s the ideal hard drive replacement and can also replace a smaller SSD in your system to give you all the room you need.
• 10 times faster than a 7200RPM hard drive
• More reliable and durable than a hard drive
• Multiple capacities to meet your needs
High read/write speeds
Its high read/write speeds will not only increase performance but also breathe life into existing systems. -
Marvell controller
UV400 is powered by a four-channel controller that delivers impressive speeds with both compressible and incompressible data. It has a processor optimized for performance and endurance. -
Rugged reliability
UV400 is shock- and vibration-resistant for rugged reliability in notebooks and other mobile computing devices.
- Kingston SSDNow UV400 - solid state drive - 480 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 480 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, rugged, Marvell 88SS1074 controller
- 69.9 mm x 100 mm x 7 mm
- 57 g
- 3-year warranty
- Capacity
- 480 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.9 mm
- 100 mm
- 7 mm
- 57 g
Performance
- SSD Endurance
- 256 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 500 MBps (write)
- Maximum 4KB Random Write
- 35000 IOPS
- Maximum 4KB Random Read
- 90000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 0.693 Watt (average) , 0.672 Watt (idle) , 0.59 Watt (read) , 2.515 Watt (write)
- Limited warranty - 3 years , Technical support
- 0 °C
- 70 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
