Kingston 480Gb SSDNOW A1000 M.2 2280 PCIe NVMe 3.0 x2 SSD
Quicklinx: DJXVWS00 Mfr#: SA1000M8/480G
Form Factor: M.2 2280
Capacity: 480GB
Interface: PCI Express 3.0 x2 (NVMe)
Type: Internal hard drive
Select:
£56.36 ex VAT
£67.63 inc VAT
Kingston's A1000 solid-state drive is an entry-level PCIe NVMe solution. A1000's single-sided M.2 22 x 80 mm design is ideal for notebooks and systems with limited space. Using a PCIe NVMe Gen 3.0 x2 interface, 4-channel Phison E8 controller and 3D NAND Flash, it offers read/write speeds of up to 1,500 MB/s and 1,000 MB/s. It's twice as fast as a SATA-based SSD and 20x faster than a traditional hard drive, offering exceptional responsiveness and ultra-low latency.
Kingston A1000 - solid state drive - 480 GB - PCI Express 3.0 x2 (NVMe)
Solid state drive - internal - 3D NAND Technology, NVM Express (NVMe), Phison E8 controller
480 GB
NAND Flash Memory Type
3D triple-level cell (TLC)
M.2 2280
22 mm x 80 mm x 3.5 mm
7 g
5-year warranty
480 GB
M.2 2280
22 mm
80 mm
3.5 mm
7 g
Performance
SSD Endurance
300 TB
Internal Data Rate
1500 MBps (read) / 900 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
90000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x2 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
0.011748 Watt (idle) , 0.075623 Watt (average) , 0.458 Watt (read) , 0.908 Watt (write)
Software Included
Coupon code for hard drive cloning software
Windows 8 / 8.1 / 10
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Capacity: 480GB
Brand: Kingston
Price Range Ex VAT: 50 - 100
