Kingston 480GB DC1000B M.2 2280 NVMe SSD
Quicklinx: FLVSWS00 Mfr#: SEDC1000BM8/480G
£73.84 ex VAT
£88.60 inc VAT
The Kingston Data Centre DC1000B is a high-performance M.2 (2280) NVMe PCIe SSD using the latest Gen 3.0 x 4 PCIe interface with 64-layer 3D TLC NAND. This is ideally suited for use in high-volume rack-mount servers as an internal boot drive(s) as well as for use in purpose-built systems where a high-performance M.2 SSD is needed. It supports maximize drive bays in which boot drives internally frees up front loading drive bays for additional data storage.
Optimized Server Boot Drive On-board (PLP) power loss protection Application optimized capacities (240GB & 480GB) Self-Encrypting Drive (SED) with AES-XTS 256bit
Kingston Data Center DC1000B - SSD - 480 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
480 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
M.2 2280
PCIe 3.0 x4 (NVMe)
NVM Express (NVMe), Power Loss Protection (PLP), S.M.A.R.T.
22 mm x 80 mm x 3.8 mm
8 g
5-year warranty
480 GB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
22 mm
80 mm
3.8 mm
8 g
Performance
Drive Writes Per Day (DWPD)
0.5
SSD Endurance
475 TB
Internal Data Rate
3200 MBps (read) / 565 MBps (write)
4KB Random Read
205000 IOPS
4KB Random Write
20000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
1.9 Watt (idle) , 1.81 Watt (max read) , 5.47 Watt (max write) , 1.74 Watt (average read) , 4.88 Watt (average write)
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Type: Solid state drive
Brand: Kingston
